Battery problem
With just ignition on after a minute the yellow battery light comes on if gose off when I start car. The start stop works ok for about 3 to 4 hours then stops working last week it stopped completely so I charged the battery then it worked again for 3 to 4 hours.
Any ideas?
  • Replies 78
  • Views 5.6k
  • whippersnapper
    whippersnapper
    Got my car back. Verdict was defective battery so replaced with new one
  • whippersnapper
    whippersnapper
    Took the car for an errand today and it stopped and started so many times I turned it off. So it works properly now :)
  • I 100% agree, get the multimeter out and start doing some battery voltage measurements.
Removed due to early morning brain fade 🙃
Edited by PetrolDave
Sorry - what is the question?
Do you think the battery is not being charged correctly by the vehicles alternator - even though the alternator symbol is extinguishing after the engine is started?
Do you have a meter you can use to measure the battery terminal voltage while the engine is running?
39 minutes ago, PetrolDave said:
If you don't tell the battery management you've fitted a new battery it assumes the old battery is still fitted.
I'm not sure but I think the BMS is SFD locked on the Octavia 4?
OP says battery was charged - not changed.
My bad, too early in the morning!!!
If start/stop only works for a few hours then that suggests the battery charge state isn't being maintained. How old is the battery?
Do you get either of these on the display
Car only 1 yeas old I've had it 3 months
No just stops working i drive all day it's fine for about 4 hours
You seem to be saying that you think the alternator is not charging the battery correctly - even though the alternator indicator is extinguishing while the engine is running - is that correct??? - If so, as I posted earlier, you need to check the battery terminal voltage while the engine is running.
Do you not see either when it is working?
No just the A with a line through it
What should it be at
Running
Idil
Running
Idil
There isn't one answer to that as the car has a Battery Management System that dynamically changes the battery voltage.
Before starting if the voltage is below 12V then that's cause for concern, when the engine is first started expect something around 14V but this will drop to something over 12.5V after a few minutes except when you come off the throttle when it will rise again to around 14V as the "micro regenerative braking" comes into effect.
When the a with the line through it appears it means the stop/start system is operating but has chosen not to stop the engine because the battery is not within the parameters required for the system to function.
There maybe too many other demands on the battery Aircon, cooling fan , headlights, heated seats etc.
Or the battery is below 80% or a combination of all above.
I would doubt the battery or alternator have a fault with the age of the car.
Potentially it is use and the demands of the eu that is stopping it working.
To explain or prove that theory needs a bit of the cars history
What is the mileage now and what was it three months ago at 9-10 month old.
Are your trips often or not and short or long journeys
https://www.varta-automotive.com/knowledge/articles/article-details/start-stop-does-not-work
Edited by Stonekeeper
The messages that @Stonekeeper is referring to are in the vehicle status display (in the infotainment system) - not on the instrument cluster.
Possibly not a good assumption to make that a one year old alternator or battery in unlikely to be faulty - My Octavia had both replaced at less than a year because they had failed.
I agree it's not impossible for a faulty component to have been installed at the factory but I find it best to eliminate other simpler possibilities before taking it to the main dealer for a diagnosis and repair under warranty.
They will initially almost certainly just dismiss with charging the battery back up properly then giving it the customer back.
Especially stop/start because there are so many reasons it deactivates.
If the op had said the crossed out a was not visible it may be different. But that does suggest it's working.
One question i have missed is "When the op charged the battery where did he connect the negative lead of the charger if the battery remained connected in the car?" and "What charger was it and for how long?" sorry that's two questions.
@Tonyduncan could help himself by answering some of the pertinent questions already asked.
Edited by Warrior193
added information
Calling @Tonyduncan please can you answer some of the above questions?
Not been online for 3 - 4 hours so possibly driving. I'd wait until the eveing for a reply thumbup
6 minutes ago, Lee01 said:
Not been online for 3 - 4 hours so possibly driving. I'd wait until the evening for a reply thumbup
Hopefully,
a good 3 hour drive may fix the problem.
Car has done 4000 miles in last 3 months short and long journeys 8 hours a day didn't have this problem with my 2015 skoda octavia only once after 7 years and had to change the battery.
Sorry just got home
Negative leas to engine block
Charged full
Start power was 12.4v
Finished was 13.2v
Nothing in the status display
