Buying Advice: Skoda Karoq
Hi all,
I’m currently in the market for a 2019 Škoda Karoq 1.5 TSI DSG (mileage between 40k to 50k) and would appreciate some owner input before making a purchase.
I understand this model uses the DQ200 7-speed dry-clutch DSG gearbox, so I’m trying to get a clear picture of what to check and ask the dealer about.
A few questions and points I’d appreciate any feedback on:
  • Should the gearbox oil have been changed by now, or is it “sealed for life” on this model?
  • Are there known DSG issues to look out for on test drives (jerky low-speed shifts, hesitation, noises, etc.)?
  • Have there been any software updates or recalls that improve the smoothness of the engine/gearbox?
Windscreen delamination appears to be an issue affecting all Skoda models. I’ve seen one Karoq 2019 with milky edges starting to lift. A Kamiq 2020 and another Karoq are showing early signs of windscreen delamination. So I'm wondering if that’s a wider issue or just a coincidence.
Any tips or real-world experiences with the 1.5 TSI DSG combo would be really helpful — I’d rather go in with eyes open before I commit to one.
Thanks in advance!
Edited by JCK
There will be far more knowledgeable people on here than me, but here is a bit of 'advice' gained from my 2 week ownership of a 2025 Karoq SE L with the same engine and transmission.
There can be some hesitation when pulling away, due to a few factors.
1). The main 'issue' is a combination of 'stop start' and 'auto hold', (plus see 3).
With the car engine stopped, and autohold engaged, as soon as you want to move, there is a short delay. The engine starts first, then the brake disengages.This is to be expected. But if you're not used to it, and want a quick smooth get away, you might be disappointed. I would suggest that on a test drive, disengage autohold and stop start one at a time, and see if you're happy with how it all works together. Also, when parallel parking involving a few drive/reverse changes, both of these together can be a pain. I take both off when parking on a level road, and stop start off when doing it on an incline. Note that the autohold in reverse takes a bit of getting used to as you're rarely trying to move off quckly, so it takes a bit of practice to avoid jerkiness. Again, try this manouver out on a test drive.
2). The whole jerkiness appears worse when the car is cold. When it's warmed up a bit, I don't find it a problem at all.
3). The gear box tends to want to move up the gears faster than you might be used to or expect. Again, this isn't really a problem, but look out for it. If the car has a sport mode, check it out on the test drive and see how it compares. And do that in combination with 1). I'm still exploring this, as I've not had the car long enough to check it out!
4). Honestly, depending on your driving style, you might not even notice it. I try and move off firmly and steadily and rarely notice it now.
Don't let what I've written put you off. These are good engines and gearboxes, and work well together. I love mine, and would buy it again in an instant.
Edited by Philly112
Well... I've just driven the car and tried to get it to judder, hesitate, jerk etc. And I couldn't, it drove smoothly. Whether my driving style has changed, or the car has 'bedded in' I don't know. Be interesting to see how it performs once the weather gets colder.
Thank you @Philly112.
Ours can judder a bit when driving away after reversing off the drive from a cold start.
It's a bit weird really, it seems if I think about it, it doesn't do it. If I forget, then it does. We don't use it much and it reminds me of a manual car we used to have that did the same, and that was put down to condensation on the flywheel, but I don't think that can be the case with a DSG.
