Service advice, 1.5 tsi engine with dsg
Advice welcome, 18k & 36k services incl. with car, both just oil & filter + inspection carried out by main dealer. 54k due soon then 72k next year so I'll use independents. Anyone know whats req'd over and above oil/filter at these 2 intervals. Ideally I'd like to spread the work/cost equally over the 2 services
Both Oil & Inspection Services, but there were Extras that were part of the Service Regime as on what is called Variable or Flexible Servicing.
If doing to Manufacturers Recommendations, Guidelines, Advice, Specification or Schedule.
Spark plugs changed which are a 4 year / 40,000 miles schedule item.
Were they replaced.?
Pollen filter is at 2 years / 20,000 miles.
So has it had 2 filter changes.
Has the Brake Fluid been changed @ 3 years / 30,000 miles?
Thanks for your reply.
2 year old car is on long service regime so had oil & filter with inspection at 18k then same + pollen at 36k.
54k service due soon so I'll add spark plugs and brake fluid to above this time around. Anything else to include like air filter or fuel filter? Does DSG require any maintenance or is it sealed for life? Advice very vague on this one.
The DQ200 DSG is not actually 'Sealed for life', both oils can be changed, but there is no Service Regime, guidelines, advice or schedule from VW / Skoda.
The Air filter should not be left till 6 years / 60,000 miles as per the Skoda / VW schedule.
Checked at every service and replaced as required is 'Simple Clever'.
No fuel filter schedule.
