Engine sensors malfunction
Hello! Searching for an advice!
Check engine light comes out on dashboard, engine running normal. No loss of power or other symptoms. Here are the fault codes that VCDS showed (i do not have other parameters)
Octavia 3 FL, 2.0 TDI RS
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BS HW: 04L 907 309 R
Component: R4 2,0L EDC H24 1541
Revision: B5H24--- CVN: B4EC2C4A
Coding: 011D0012036401080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
ROD: EV_ECM20TDI01104L906026BS_002.rod
VCID: 7CA1F4ED5668993AD31-8028
VINID: 91D49A6C779509A0010840C91440064B1D
3 Faults Found:
9764 - Exhaust Pressure Sensor 1
P0470 00 [00100000] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
5253 - Particulate Filter; Differential Pressure Sensor
P2452 00 [00100000] - Elect. Malfunction
25713 - NOx Catalyst/Trap Bank 1
P2000 00 [11101101] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 249135 km
Date: 2025.08.11
Time: 17:16:45
Engine speed: 1559.00 /min
Normed load value: 31.8 %
Vehicle speed: 55 km/h
Coolant temperature: 91 °C
Intake air temperature: 100 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.540 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 1 1 0 0 0
It might be worth forcing a DPF regen then clearing codes, and seeing what comes back. Not sure of the exact process, but it can be done via VCDS. A quick google should yield results :)
i cleared the codes and the car seems to be working fine past 400-500 km, and no check engine comes on dashboard. i will come back with updates and maybe a solution. thanks anyway
