New SD card not being recognised
Hi folks,
I've recently got myself a 2010 Scout with what I believe to be the Bolero system. It doesn't have an sat nav in it, not an problem. It has a button that say 'phone' but all that does is mute the radio! Any ideas if it will actually connect to a mobile phone. When I try and connect via bluetooth, there are no obvious connections available. I'm guessing the answer will be "nope"
It does have a slot for an SD card. I've copied a load of tracks onto an brand new card but when I insert the card, I get a message about the card not being recognised. Does anyone know a way of testing if this can be resolved.
I have discovered that it can take 6 CD's so my personal music choices can be expanded. I also have a Pure Highway digital radio so all is not lost music wise.
Cheers.
I have the exact same system. I have no problem with an SD card but I did have to format it first so try reformatting your card if you have noy already tried that.
As an aside, I had an SD card that had been used in a security system and when I tried to format it again for other uses it kept on reporting "damaged storage" when used for audio.
The SD card plus 6 CDs gives a large collection of music. In addition there is a aux-in socket in the central storage box which allows you to input more sounds from an external device. There is no blutooth connection for a phone.
An expensive option was another box under the drivers seat for phone connection. Personnally I prefer not to be on the phone whilst driving.
Hi pikpilot,
Thanks for the reply.
I thought that would eb the case re bluetooth. Great, I can just ignore the phone when it rings, haha.
I have another SD card and will format that and see what happens. I'll be disappointed if it doesn't work, but heyho as they say.
It's gone quiet.
I have formatted several discs and put music on them, but no, nothing. Although one card was recognised but the car responded with "No music on card" I think I'm barking up the wrong tree here. Never mind.
Have you formatted them using exFAT, FAT32 or NTFS? I seem to remember that they need to be in FAT32.
I'm think I've tried all three, can't remember. I can do it again, but it will be tomorrow as I've got my slippers on and it's raining. There is no mad hurry. Ta.
Try also in FAT32 putting on the individual tracks in order rather than copy and pasting the whole file.
Also try with an SD card of 64Gb.
