AutoStart function key turn! Strange symptom
Skoda fabia 1.2 tsi 2014 86hp. new battery :))
I have the one tap key function (dont know the correct name)
You throw the key in the contact and twist once and it crancks for you. Do not need to hold the key in the turn position until the car cranks.
autostart function : when i do the one turn the car just cranks and cranks and dosent start. like its no spark just cranks
...But if i do a classic twist and hold the key in the crank position it will start instant like no issues
Any ideeas?
  • 3 months later...
hello,
the autostart got fixed after the missfire / hicaps got fixed for fabia mk 2 with stage 1 to 130 hp
but for safe messure i will change the fuel pump relay/ start stop
to fix hicaps/ misfire
all 3 new engine mounts
Spark Plug 1.4TSI RS Brisk - 4 pcs
Ignition Cables 1.2TSI Tesla
Kamoka ignition coil
