Part Number for Exhaust Gas Temperature Sensor - CRMB engine
Hello wise ones!
I have a 2015 Octavia Scout with a CRMB engine.
After a recent cam belt change, I started getting fault: P242C00 Exhaust Gas Temperature (EGT) Sensor Circuit Low for Bank 1, Sensor 3 (static)
I have identified the sensor location as right above the cam shaft belt and if I give the wires a wiggle at the sensor, I can sometimes get the fault to clear.
I know that it was removed and replaced as part of the cam belt replacement process, to make room to remove the cam belt cover.
I cannot prove that it was the mechanic that caused it, so I just want to replace it.
The problem is that I don't know the right part number and there seem to be a number of possible variants. I can't see a part number on the exposed part of the sensor (see photos).
Can anyone give me the right part number and a good parts place to get one?
Edited by egbcars
Typo - Correct Hell to Hello
