Rear nearside spring
Afternoon all.
Does anybody know the correct part number for a nearside rear spring please?
Found the cause of metallic rattle, very top of my spring was stuck in the basement of the arm, spring still functions, just not ideal, about an inch missing.
Online shows two different springs. No wish to order both.
Car is a superb 2.0tsi 2012 Saloon.
Any advice welcome.
Send request with VIN to PM and I will check correct part number
Both the gknautomotive and Kilen/Lesjofors online spring catalogues think that it's a 1K0511115BH rear spring for a standard ride height Superb MK2 2.0TSI hatchback.
If the Superb MK2 has build codes 1JA and 0YD, then the rear spring is 1K0511115BH. One white paint mark and two orange paint marks also means that it's 1K0511115BH.
It's best to change both rear springs at the same time. Changing just one spring could result in one side of the car being higher than the other.
Rear coil spring (Superb MK2)
1
1K0511115BH
ONEwhitepaintmark
TWOorangepaintmarks
1JA+0YD
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/5/511/511000
Sachs 994 329 rear spring (matches 1K0511115BH)
https://www.autodoc.co.uk/car-parts/oem/1k0511115bh?supplier%5B%5D=32
Edited by Carlston
Thank you for the info, cannot remember my build code, but will look into it.
Need to order one this weekend, am still using the car as have no choice up here.
Spring broke at the top so is still doing its job, sadly the rubber damper fell out whilst up on the stands.
