Skoda superb iv 2021 help add map car is imported feom cz current in israel how to downlod maps upadte
How to do it pkease
Download, extract, copy the 6 files directly to the root directory of a USB stick. Then update in the car.
https://mega.nz/file/lrdBWB6b#5mBUd67LKWBmyvcjNjP1iH_DJvYu2qSxica97cRLmtw
Its not working . I need a vag swap code for country the car is imported the navigation dosent work in my country . Installing things on a usb dosnt do anthing
It is mib 3.
They're asking about a map update. They haven't mentioned anywhere that the navigation system isn't activated yet.
I suspect the update portal (and presumably OTA server as it's likely they're one and the same) offers regional files based on the VIN. CZ will be linked to ECE files, while Israel probably needs ROW.
If that's correct it'll need someone to change the region in the car's build sheet, if that is even possible.
All the stop signs and speed signs working only the navegation problem .i contacted a vag workshop in israel they said i need a swap code currntly its unvalible to buy one maybe in a few monthes in 2026 now its not possible
This is the versioin
This the system
How can i update it to a new version and what it is ???? Can i cange from eu to raw
