Crankshaft Sensor 2.5V
Hello there,
My engine (1.4TDi Fabia 1 2007) won’t start and the OBD says no crankshaft sensor signal.
Troubleshooting shows at the disconnected plug:-
Earth is good
Sensor has good ohms
Signal and power both have 2.5V…!!!
but 2.9V when cranking.
No continuity between power and signal.
Any ideas, is the ECU toast ? Thanks for all help.
  • Sponsor
What is your engine code?
If it is BNM or BNV then the circuit info looks like this, with no clear marking of +5V or signal, or even +, so I'm not sure you should expect to find a 'power' pin.
Later diagram for BMS engine code (first found in mk2 Fabia I think) shows something more like what you seem to be expecting, or even what you are looking at in terms of a circuit diagram:
Looks to be two different technologies of crank sensor in these two examples.
Edited by Breezy_Pete
Thank you very much for that. My engine code is BNM so I must be looking at the top option which is new to me...!!!
I haven't been able to get my hands on a wiring diagramme but reckon I need to learn how to test the circuit again now....
Looks like the sensor itself may not be a problem as no more error codes after the memory being cleared. Probably something else...uh oh.
