2.0tdi alternator replacement help
Engine CBBB.
Yeeh this is funny job. Is only possible get alternator out put front end to service position? Now its stuck at radiator (fan off)
Ive jacking engine up and down, ac compressor loosened.
Wondered also will it fit without clutch but i dont think so.
Done.
Not so bad. Ac compressor bolts off, coolant fan off, plastic bumber off and steel bumber also. Gives nice space.
I think other work is useles like engine jacking and bracket removal.
  • 9 months later...
I just did the same work for the second time, But did not bolt off the ac compressor and did not take off the bumpers. I just raised the engine and took the radiator fan off. Same engine. 2h in total.
Recently Browsing 1
