Headlamp Washer pulling current with engine off
Hi
Had a flat battery the other day, replaced it with a new one as the old one was getting on a bit.
New battery has now gone flat as well. No internal lights or cigarette lighter was left active/plugged in. I've had a play with the multimeter and found that Fuse 36 (headlamp washer) was blown and when it was bridged with the multimeter, there was current going through, so I'm thinking a parasitic drain there?
I pulled the front left headlight but couldn't find a power connector to the headlamp washer as the rear - could anyone explain where it is so I can continue hunting this parasitic draw!
Kr,
Ben
Not sure on the Octavia but the fabia has a connection underneath near the bottom of screen wash bottle that connects to pump. From memory its accessible from underneath but may require engine under tray or plastic wheel arch removal.
Alasdair
