Windows switch question
me again with our new (to us) fabia mk3
I noticed that only the front driver windows is automatic and the rest is not, therefore we can't close or open the windows with the key.
What can I do to have the automatic window on at least the passenger side and to enable the open/close windows function with the key ?
Thanks )
If your car is from 2011 then you really want the Mk2 forum. I'm not sure you can have what you want but the Mk2 owners will know better.
Thanks for your reply @nta16 but i'm pretty sure it's a mk3 as it's from 2014 )
I'm not sure where you've got the intel that's it's from 2011.
From your 'Author stats' (arrow top right corner of post). 2014 is probably Mk2 model in UK. Mk3 models have NJ in their VIN/chassis number, I forget what might be in the Mk2.
If it's a Mk3 the subject has previously been covered here quite(-ish) recently with information and details.
HTH.
ETA: the subject of whether Mk2 or Mk3 has also been covered here with details and information, including IIRC photos of Mk2 and shaper lines Mk3.
I know it's a mk3 D
It's like the one in the picture.
I'll try to search the forums about the window thing )
@nta16 i've just noticed what you mean by 2011 in the author stats, IDK where it came from as i'm sure I did put 2014 D
No problem, I'm the King of typos.
You might also be better to change your profile to show 2014 rather than 2011 and if you want to perhaps add more details of the car, my profile as an example only. -
You might need to use the site's search facility or Google, which will return you to this forum most likely, if I find it I will put a link in this thread.
I'll update it like your's later, thanks for the tip )
I've also changed the year D
I think if you read down the posts in the following thread it covers what you might want to know. If you have hand crank winders at the rear, as with my wife's car, then I know you can't get open/close off the remote key fob because that requires a different bit(s) for the windows control I forget what they might call the pack for this, then you would need to program all in.
HTH.
All the windows are electric, no crank.
I'll check the post, thanks a lot )
