Keyless faulty
Got a message the other day that the keyless was out of function.
So connected my obdeleven to read out the codes and got B116F11 code saying "driver access/start system antenna" short circuit to ground.
Any suggestions on that? Is the antenna and in that case where is it placed in the car?
On another notice i got the code, cleared it and then drove the car to work and back with out it popping up and then i tried to lock the car with keyless touching the doorhandle which worked, the car locked. But then it locked it self like 5-6 times in a row without me touching the car.
That made me maybe suspect the doorhandle itself but i dont know....
  • 2 months later...
Have you made any progress on this? My passenger door is not working anymore with Kessy. I have got the same fault via VCDS.
Yes, i changed both front doorhandles and now it works fine. It was the driver doorhandle that made the faultcode to pop up but changed both because passenger doorhandle did not work either.
Thank you for your reply. How did you source the doorhandles? Did you buy them new and had them painted?
I was lucky and found both handles in a junkyard online from a car with the same color and low milage for a good price.
