Climate Change Problems!!
Hi, again, this is my second post as I am new to this.So firstly many thanx to those who responded to my first post re replacing a faulty climate control unit.Saved me a bundle!But after a simple plug in the unit seems to be working fine, except not cooling the air.Which is the whole point especially at the moment.
Does anything need calibrated, what is VAGCOM? or maybe I need to repressurise the system?
Any advice appreciated.
Check its not in 'economy' mode
VAG-COM is some software which when used in combination with the correct connector simulates the VAG tool that the dealer has for controling your cars electronic systems.
You should set the motors with diag equipment and recheck fault codes.
