Parking sensors contol module location
Hi Guy's
Anyone know where I can find parking sensors control module?
I've been told to look on the right side of steering column but I'm not sure.
Yes, under the steering column on the right, you have to remove the storage compartment. On a RHD car that is.
LHD is similar location but attached to the fuse box.
Edited by Binx1310
Hi Binx
Thanks for quick respond. I need to have a look when wether will be better.
Basically my parking aid throwing error, on OBD11 showing a front left sensor for automatic parking but someone says it might be control module. Any idea how to check it?
Best regards
Marcin
2 minutes ago, MRudek said:
Hi Binx
Best regards
Marcin
Not a clue, but its likely to be sensor if OBD11 says it is. You could try swapping the front left sensor for the front right sensor and see if the error moves with it. If it does, then its definitely the sensor.
The sensors are relatively easy to replace.
