280/280 Camshaft question
Hi everyone ive got a question about running a 280/280 original factory skoda camshaft that is from a skoda 120S race car from 1971. I am planning to put into my built favorit engine that goes as follows:
-136B favorit stock bottom end
-Felicia slightly ported and polished head with stock valves and stronger valve springs running a full set of aluminium pushords with reinforced tips
-lightweight flywheel (4,9kg)
-stock favorit dizzy
-standard Pierburg Lekr (mechanical secondary done and rejetting are in the works)
-gr.A air intake and gr.A muffler
- 4-1 exhaust manifold with stock mid pipe
Now the question is this is a viable street camshaft and did anyone run a similair setup i am wondering about the usable RPM range on this setup with these cams. Would be driven on the street and the occasional local trackday or event.
Edited by Snn
added info
