Alternative mounting points for Rear Speakers?
Hi All,
After recently replacing the OEM front speakers with brand-new JVC ones (kudos again to the excellent guide by @Pinkwafer) I would like to add some speakers in the back, but preferably NOT in the rear doors as they are too low down and there is no existing speaker cabling going to them.
I considered mounting some smaller speakers in the D-Panel internal trim, but after removing one I discovered that there is only around 2cm clearance there which is no-where near enough room. I could mount speakers on the Rear Shelf but I would have to add some accessible connectors to the cabling for the rare times I need to remove that shelf.
Are there any other places that people have seen rear speakers mounted? The vehicle is a 2010 pre-FL Yeti.
I can only comment on my 2017 model, & the rear speakers were most adequate.
Plus you can adjust the music power up or down on front or rear speakers.
So with good speakers, I found the sound system wasn't that bad at all.
