1.4TSI - lambda 1 stuck rich
Škoda Octavia Mk3, 2013, 1.4 TSI CHPA, Manual driven 113k km (roughly 76k miles).
Symptoms: MIL came on after long highway drive (about 130 km each way).
But engine runs completely normal: smooth idle, normal power, no hesitation, no oil consumption, excelent fuel consumption ~5.4–5.7 L/100 km
Fault codes read:
Code 1: P2196 – O2 sensor signal stuck rich Bank 1 Sensor 1 (active)
Code 2: P2271 – O2 sensor signal stuck rich Bank 1 Sensor 2 (passive)
Spark plugs and coil 4 was replaced ~4500 km ago during annual service. Coil was replaced due to lambda 1 being stuck rich and missfire codes on cylinder 4.
Current situation: Codes were cleared and MIL didnt return in the 30min trip home.
What should be next step? Read live data of lambdas? Replace lambda 1 or remaining coils?
  • 4 months later...
Hi I got the P2196 error code today, do you have any updates, what was the issue with your Skoda and how did you mange to fix it?
Fix was to replace both lambda sensors.
After replacing lambda1 (pre cat, B1S1), it started to throw active codes for lambda2 (post cat, B1S2).
After replacing both sensors the fault (codes or MIL) hasn't come back. My guess is that the car had a missfire problem and lambda sensors problem - both of which are long gone now.
