No power to washer pump
Hello,
My windscreen washers are working, both front and rear. Hower the washer water pump does not, there is no electricity at the connector for it.
I recently replaced the water tank as I'd caught the nearside wing on a low, unseen fence reversing from a tight spot, which cracked the original tank.
Is it likely that this event damaged the wiring for the pump motor.
Many thanks in anticipation!
  • Sponsor
Check fuse 15, I think.
Hello, I have checked fuse 15, bless it.. hence the wipers are working, not the washers as I incorrectly stated in my original post. Does the washer pump have its own fuse perhaps?
Cheers!
  • Sponsor
No other fuse for washers as far as I remember.
Could well be wiring damage, or connector corrosion?
Edited by Breezy_Pete
  • Sponsor
You're aware that front and rear washing is just opposite polarity of 12V to the motor, I suspect.
Thanks for your advice Breezy_Pete, yes I'd understood that polarity reverse regarding front and rear washers.
Best wishes!
