Snapped ABS sensor
Have the ABS traction lights on the dash. I tried to remove the rear drivers side sensor.. And snap. Any advice on how to get the remaining bit out??
Edited by Dan_dorset
I did the same and ended up removing bearing and drilling it out as I didnt want anything to get into hole. You could see if you could get an easy out or self tapping screw into the bit thats left plus soak overnight in releasol before trying to remove.
Alasdair
What's the access like once the bearing has been removed?
From memory it wasn,t that easy. I have snapped a few but last time I think I heated it up slightly and knocked it through rather than pulled out. I have both Fabia and Octavia and the Octavia was a bit more tricky.
Alasdair
Sorry just realised your talking about rear not front. Not sure on them as I did the front.
Alasdair
