Recirculating Button not working
Have come to use the A/C for the first time this past week and noticed that pressing the button for the recirculating air doesn’t appear to work.
Button presses but nothing happens it doesn’t light up and stays off
Also through the media center doesn’t do anything, wondering if anyone has come across this before? Or is it a trip to Skoda?
Edited by tombee
Yes. Mine was stuck. The flap is above the pollen filter above the glove box. You can try moving the flap with your fingers.
But first try a recalibration. You can do it with carscanner or by holding AC and front vent button for a few seconds until the lights start flashing.
If not then it will be the actuator. I had to change the one for the main diverter. £10 from Amazon for a non genuine. And about 20 Mins to change.
Edited by Binx1310
It would appear I have a fault with the flap, will try and see if I can move it
The calibration thing sorted my stick recirc flap. This is just above the pollen filter so sometimes detritus on the filter can get stuck in it. I think mine might have been the extra wiring from the reversing camera fouling it too.
But could be a failed actuator. Not expensive and pretty easy to change.
Edited by Binx1310
duplicate
Edited by Binx1310
Can’t delete
Ahh I have that wiring also for my camera, will check that out.
I do have warranty but be nice to resolve with a visit to them
Can't feel any of the wiring being in the way, I have found the unit but tried to move the wheels by hand and they are stuck fast so think the unit might of gone.
8 minutes ago, tombee said:
Can't feel any of the wiring being in the way, I have found the unit but tried to move the wheels by hand and they are stuck fast so Ithink the unit might of gone.
Some are on a worm gear so you won’t be able to move them if the actuator isn’t trying to move them too.
If you carefully remove pollen filter you can see the flap at the back of it. It’s recommended to slip a bit of cardboard beneath filter to catch any crud that is sitting on top of filter otherwise it goes into the fan.
Or just take it to dealer If it’s still under warranty!
I have been able to get the unit out and then tried all the cables moved and it still doesn't work, I might try the reset but it is booked in with the dealer for the week after next
If it’s got warranty and the warranty covers it the it’s 100% back to the dealer job.
Yup, the extended warranty covers it. I have a hire car also, a newer Superb
Also noticed that I appear to get warm air blowing now when on LO setting for air temp, so have updated the work log for next week
Sounds the the actuator for the temperature control isn’t working either. With the car up to temp, If you set it to coldest then slowly increase temp by 2 degrees every few seconds until hi does the temp increase at all. If it does then it may be that the aircon needs degassing rather than a diverter issue.
The air on does struggle to cool the car, but the temp does get hotter as you go from LO to 26 degrees etc
The air being warm is noticeable when the car is warm when set to LO
Just an update, this is going to be resolved via Skoda as part of Warranty claim they have done.
It was the motor for the flap which is stuck
That’s good. Relatively quick and easy fix but if it’s covered by warranty even better!
Is that just the recirc or the temperature control too?
They seem to suggest that the dash has got to come apart etc, as they need it for 2 days but I do get a car, which I have found as car forsale at £30k.
So maybe a little more work and additional they have found, either way I need it fixed before going to France next month and then Devon the month after.
yea depends which motor is gone. I think glove box out at minimum. Most can be got to from there but rather academic if it’s all under warranty! Hopefully that’s it all sorted!
It did say on the video I was sent when they inspected the car after the warranty claim was put in, they didn't mention anything about the de-res pipe or Blstien's as they walk around the car underneath.
Just hope its sorted, warranty does seem to be good when justified, with the screen being replaced the other month also.
Car has been in since the 25th, I have a courtesy car, just waiting for an update as they have been short staff etc.
But with the massage seats in the 26 plate Sportline I am not sure I want my car back now haha
Edited by tombee
Car is fixed, but they are wanting to QC with the original tech, who is off till Monday so I have the above for over the weekend again and a trip to the British GP as well so should be nice...
What engine is it?
51 minutes ago, Binx1310 said:
What engine is it?
Its the 1.5 e-tec mild hybrid
Got the car back last week, back in tomorrow to sort loose trim pieces and the steering wheel not being straight.
But the A/C and Recirculation button is working! France next week
getting there then!
We are off to France in the Kodiaq at the end of July. Enjoy!
