Check oil level warning - level seems fine
  • Sponsor
14 hours ago, doctor_smoke said:
Hi guys I have the same problem with my MK3 Octavia 1.8tsi , the error just started few months ago so I thought it was a faulty sensor , which does not show up on a obd scan
Thinking it was a faulty sensor I went ahead and got that changed by cross referencing the part number from the old sensor
03C 907 660 M
6PR 009629-05
I bought the part from TPS but I did not get the exact part number on the sensor , cause apparently they changed the part number
06K 907 637 B , fitted It to my car and it didn't make any difference so i thought maybe because the part numbers are different that it failed to rectify, then I ended up on this Czech website called Skoda parts and looked for a sensor with the engine,model... and so on it said that a Hella part would be the right one so I ordered that without doing any research because it had the part number from my old sensor along with another number 03C 907 660 T
03C 907 660 M
Now I've fitted the sensor today while doing an oil change and the problem is still there , what do I do ?
Have you read the thread I linked?
According to LLLparts 03C 907 660 M was replaced by 03C907660T. The Hella part number I think should be 6PR 013 680-011 according to autodoc etc If its the correct hella number it maybe a wiring,connection issue. Check for worn or broken wiring.
Alasdair
Recently Browsing 2
