Ghost speed limits
Thanks. I'll have a dig about in the settings
The speed limit on most of the minor c roads around north northumberland register 20mph despite speed limit of 60 is very annoying and obviously a mapping error
I haven't found a way of switching off the speed limit warning permanently, I have to switch it off every time I restart the car.
Ditto for Lane Assist.
I don't think you can permanently switch off the speed limit warning (the chimes when you exceed whatever Skoda thinks the limit is). I actually like this feature in case I accidentally miss a speed limit change on an unfamiliar road, but you do need to learn not to slavishly react to it.
But you can turn off the speed limit following, where the car automatically changes speed to follow what it thinks the limit is. My opinion - and I think the consensus from this thread - is that it just doesn't work reliably enough to leave it engaged and could be potentially dangerous.
OBD11 can deactivate it as in stop it automatically turning back on . ( one ovens few feature which are offered on SFD2 cars ) I have not tried it as it’s a useful feature when the maps are working and also not sure how VAg would react to the setting change or if the online updates would just reset it
