Enyaq aircon
Good afternoon all.
After not using my heater/blower for a couple of months. Turned on last week and aircon was blowing 'tepid' air.
Have been to dealer this morning.
They did a regas, confirming there were no leaks.
Unfortunately has not cured the problem.
They want to book in for a 'diagnostic' but cannot tell me what they will do or what they suspect can be wrong !!
Has anybody had similar issues they may be able to give me some pointers towards please ??
Sorry, no idea. How old /many miles has your Enyaq done? Is it the Cooling / AC & blower you have not used much recently rather than the Heater? There is a good reason for using AC all the time other than when the weather / ambient temp is too cold for it to operate.
It is 4.5 years old with 110K miles.
Just haven't been using heater or AC over last few months as mild weather do got by with open windows.
When using, either heating or cooling, I do use AC.
Edited by Anglosaxon
Does it have a Heat Pump or not? You are always heating or cooling or setting to the same as the Ambient temp. Leaving the AC functioning costs you nothing. Air Conditioning. / Drying the air.
Edited by Evolution13
Think the only way is to either get dealer to do diagnostic or maybe get it scanned at a decent independent garage with vcds Sounds like something has failed Could be the compressor or sensors etc but without a scan its guess work
Alasdair
No heat pimp
4 hours ago, Anglosaxon said:
No heat pimp
Heat pump !!!!
Alasdair
My local dealer said it would need a diagnostic.
I asked what it entailed, they didn't know.
I asked what/how many components they would need to check, they didn't know.....
I had a similar issue with tepid air being blown in. Finally realised that I had inadvertently pressed the cabin air circulate icon on the aircon screen. Deselected it and aircon started working again
Bring back the intuitive knobs, dials and buttons for things like that.
Grinds my gears you need to use what's basically an app to turn the AC on.
  • 4 weeks later...
Diagnosed as pressure sensor at dealer, £310 to supply and fit.
