Mk3 flickering xenon -> dead xenon -> no auto
Hi. I got a xenon light that last week startet to act up with flickering. So I read here and understood and got confirmed that is the first on a path to have to change the xenon bulbs. My process was the following:
  • Flickering right xeon light
  • Turned off the lights a few days, then one day turned off and they both were dead, no life at all on auto at least.
  • changed both left and right xenon. Surpriced how easy it was.
  • The lights still dead after changed both to philips D3D bulbs. The ifht xenon bulb was clearly dead. Had different colors on the bottom, than the new and right one.
  • Checked all fuses. Didn't find any blown. My guess was that a fuse had blown since it felt unrealistic that goth went off so close to each other.
  • removed the connection from the battery to the car. Didn't in the end seem like the best choice to do.
  • Got loads of new errors.
  • After a drive much better, most errors went away.
  • The xenon bulbs now work if I place the licht switch fully to the right. This mode I've never used so far. I've only used auto.
  • On auto mode nothing works. It seems I also no got errors with the other auto functions like lane shift and functions that needs radar and similar technologies.
It feels like the flickering xenon has either blown a fuse I havn't located or that it has blown a controller the ballast or something more.
VCDS errors changed a bit before and after the battery was unplugged the car. The last status gave me following errors:
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-CKFC)
3 Faults Found:
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [00101000] - -
Intermittent - Confirmed - Tested Since Memory Clear
17158 - Databus
U1123 00 [00101000] - Received Error Message
4631 - ECM Power Relay Load Circuit
P068B 00 [01100000] - Opens Too Late
Intermittent - Not Confirmed - Tested Since Memory Clear
0297 - Steering angle sensor
B1168 16 [00001000] - Voltage Too Low
16390 - Display for Tire Pressure Monitoring
C1146 02 [00001000] - Signal Failure
1 Fault Found:
13637426 - Databus
U1123 00 [00001000] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Address 03: ABS Brakes (J104)
2 Faults Found:
Address 10: Park/Steer Assist (J791)
4 Faults Found:
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
1059 - Databus
[FAULT_CIS_ESP_FAIL]
1078 - Databus
[FAULT_CIS_SAS_INIT]
Address 15: Airbags (J234)
1 Fault Found:
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Address A5: Frt Sens. Drv. Assist (R242)
1 Fault Found:
6553600 - Databus
[LH_EPS_03_BERECHN_LW_SIG_FAILURE]
Any tips?
Edited by lhlied
Just a stupid thought, could it be that during the lightest part of the summer the xenon lights actually stays off due to that the car has a light sensor? I feel the car now work on auto if its a bit darker than midday. Could it be that I just havn't paid attention on the lights at summer since its so bright anyways that the lights doens't matter? The leds have been working flawlessly the whole time. All the rest of the errors now doesn't light up as an error. Its just vcds that reports error. Every time I've driven the car late during a day the xenon lights has worked as they should. I thought it could be a wire that had bed connectivity, but have started to realise that maybe the car works at it was designed... ?
