USB-C sockets on Kamiq
Eager to fit my Head Up Display, which I am transferring from my previous car, I was disappointed to discover there was no standard USB-A socket on the car, so rummaged around and found a C to C lead but this would not operate the HUD with or without the engine running, a bit more rummaging found a 3 way extension with 2 USB-A outlets that used the cigarette lighter socket, using my original HUD power lead the unit worked straight away, what it it with these C charging ports on the car ?
USB C is now the standard for smart phones, so USB C ports are the way to go. Be aware that the quality of the leads vary. Some leads are OK for charging, but no good for data transfer.
Agreed, a power only rather than a data cable. Not a usb c issue.
Edited by sussamb
I agree, try a power only USB lead. Also note that USB port power is limited so check the current draw of your HUD. It may well be that the only way it will work is the way you have it set up.
As far as I know all Skoda car USB ports (be it A or C) are ignition switched but you don't need the engine running.
I always found the 12v sockets being permanently live a bit of a pain especially re powering dash cams , coolboxes etc. As you have to remember to disconnect to avoid a flat battery.
Definitely missing having a power supply that is dead when the ignition is off
