GPS ISSUE: Software 330 vs 332?
So, I had some issues regarding the navi with 330, but decided do update to 332. The same thing, navi is off sometimes by 50-500m, sometimes it works. Is there a changelog or anything somewhere? What are the fixes, should i go back to 330?
Those updates are not done on their own, one needs to go to the official shop? Does updating on its own, void warranty?
Do we know when was 330/332 released?
Is there any way to check if the gps is good or bad? There is no option to see how many satellites I am pickig up?
Thank you good people
Edited by LaMpiR
Do the same position errors show on your mobile when using Google maps / Waze when connected / in the car - if yes then your ‘Online Services Controller’ could well be the culprit - expensive bit of kit.........
No. It works perfectly with my Android auto (Google Maps and Waze). Connected over wireless android auto.
Edited by LaMpiR
I'd imagine then that your GPS reception is good and not the culprit - my nav was all over the place on both the car and my mobile - dealer explained that my mobile uses the same onboard data when it connects to the car.........sorry couldn't be more help.
Any additional help guys? :) I've noticed that when in the garage, the problem is much more frequent and when outside, it works most of the time.
On 23/07/2026 at 18:41, Berisford said:
Edited by LaMpiR
  • LaMpiR changed the title to GPS ISSUE: Software 330 vs 332?
I disagree with a previous post that said Android uses the same data as built-in system.
I believe your problem may be a faulty GPS antenna - is this vehicle a Kombi?
It's a combi version. Any way to diagnose it? I tried reseting the system, but now I cannot login as a main user, always getting an error that my profile info cannot be loaded. Everything worked minutes before I reseted the software.
I think you now have two problems.
Your original issue with incorrect GPS positions is very likely to be an antenna problem - it's not uncommon for the roof seal of the 'shark fin' to fail and allow water ingress to the antenna base.
It seems that I do. Today I went from my garage and drove for 30min. Gps had the false location the whole time. I don't use, but it keeps messing my speed sign reading and the warning pops up. I am driving 80km/h with 80 being the speed limit and suddenly it drops to 30 because according to the car, we are in some street which has 30 speed limit and it's 700m away from us. The car was then parked outside for 4h and the drive home, it worked perfectly.
I've updated the system on my own, but will be going to the service center on Wednesday (different issue). Do you think me upgrading on my own voids anything or creates additional issues for me?
Unless alterations were made other than simply carrying out a normal software update, I cannot see how that could affect a warranty in any way.
Actual modifications might if they do spot something non-standard though.
No, just downloaded the file here and updated it over usb, no modifications whatsoever.
Resolves the user login issue at least :) Maybe it needed a bit after the reset.
Edited by LaMpiR
Recently Browsing 1
