Kamiq navigation
Hi
We got 2024 kamiq on Saturday.
Husband tinkering with infocenter settings and somehow he has managed to delete the navigation button on the infocenter display. We used android auto to drive home but would like the option to use the skoda navigation is case the phone is stolen or lost. I have spent all morning trying to get it back but have had no luck. . I have tried going to the widgets but no nav shows to add. Tried forgetting phone just in case this overrides anything but that didn't work. Any suggestions gratefully received
Many thanks
@pab567
May know a way around your issue
Welcome to the forum btw 👋
2 hours ago, mac11irl said:
@pab567
Many thanks, I have gone through all 97 pages but cannot see my issue
Try to reset the unit to factory settings.
Thank you, will try tomorrow
Start the car (or turn on the ignition). Hold down the radio on/off button (volume control) for approximately 10 to 15 seconds. The screen will go completely blank, the Škoda logo will appear in the middle and the system will completely restart. After starting, check if the navigation has appeared.
But this is just a restart without reseting to factory settings...
A restart may be all you need.
Also try tapping on the HOME button and then swiping left or right to the view you want.
Nav full screen should be available by tapping the NAV button.
Thanks for all th suggestions, sorry for late reply, tried soft reset to no avail so did factory reset which worked a treat. After watching him change things again I worked out it was the privacy setting. Once he turned it to private it disappeared again and although I changed it back again neither a soft reset or switching on and off again bought it back. So another factory reset and we are good to go lol.
Thanks again for all of your help it was much appreciated.
The privacy setting is pretty powerful. Turns off a lot of stuff including NAV.
