Retro Side Assistent
So,
The Octavia 3 only received the Blind Spot Assist with the facelift. That means it uses the 5Q generation control unit.
Of course, I'm not installing anything like that. Therefore, I'm using the OEM 5Q0 radar mounts with the 3D-printed adapters, just like @Lutz91 did in his Superb.
The OEM LED is integrated into the mirror glass, but I'm definitely not going back to that solution.
Through a bit of luck and some internet research, I discovered that another Volkswagen Group vehicle also uses the same Octavia 3 mirror caps.
This vehicle has the Blind Spot Assist from the factory with a version integrated into the mirror caps.
Thanks to @Lutz91 for finding the details.
So, I ordered a set of primed left and right mirror caps from the aftermarket, just to test them. VW charges €75 each, but I paid €35 for both aftermarket caps in Spain, plus a few euros for shipping home.
Thanks to @Lutz91 for the detailed research. The following parts are required:
Control units:
2Q0907686B
2Q0907685B
Sedan mounting bracket:
5E5907455A
5E5907456A
LED headlight washer mirror caps:
565949145
565949146
Exterior mirror caps
To be added if the correct parts are available
Wiring harness:
From my supplier in the Far East...
3D printer adapters for left and right
Die Steuergeräte sind komplett, der Kabelbaum auch. Der erste Außenspiegel komplett zerlegt
Die anderen Teile für OEM Retrofit in den Außenspiegel sind im Zulauf.
Gestern habe ich am Tisch die Steuergeräte aufgebaut. Firmware sauber neu geflasht auf beiden und einen für mich vermutlich passenden Datensatz aufgespielt.
Der Octavia 3 hatte nie die 2Q0 Steuergeräte verbaut, dadurch gibt es keinen originalen 2Q0 Datensatz dafür.
The control units are complete, as is the wiring harness. The first exterior mirror is completely disassembled.
The other parts for the OEM retrofit in the exterior mirrors are on their way.
Yesterday, I assembled the control units on the workbench. I cleanly reflashed the firmware on both and installed what I believe to be a suitable data set.
The Octavia 3 never had the 2Q0 control units installed, so there is no original 2Q0 data set for it.
Due to the change in the mirrors, the LED part number has also changed:
5E6949145
5E6949146
This should clarify which mirrors are being installed.
