Which Octavia Scout would you choose?
On 24/08/2026 at 11:32, skomaz said:
Beware - some of the above info is incorrect... all Mk2 Scouts and 4x4's had DPF's, even older PD140 ones, as they were fitted with the BMM 8v engine and not the 16v one without DPF fitted to other variants.
You live an learn 👍
Well, today has been an interesting day.
Collected my, new to me, Scout and when I got home, about 14 miles, someone knocked on my front door to tell me there was a wet patch under the front of the car.
Aaahhh. What the heck.
OIL!!
I cleaned and checked the dipstick and it was DRY!!
Called the garage and it is getting taken back first thing tomorrow.
Plus the Bolero panel has gone blank. Nothing at all. I'll do some digging.
Bugger, was the oil warning light showing on the drive home?
@cwt did you lift the bonnet and check that the oil filler cap was on? Had you checked the oil level and coolant level when collecting car and before leaving with it. Maybe just the drain plug not renewed or washer when serviced or plug cross threaded.
Recently Browsing 1
