Karoq led matrix headlights
Hi everyone,newbie here so treat me gently as I am not used to forums so I hope I wo7offend you guys,
I have a 2022 karoq sport line tsi 190 which I find to be a fabulous car . I have only recently started to drive the car after many months of illness.
When I purchased the car there was a specific main beam pattern when you pushed the stalk away the beam seemed to project centrally then spread out to the sides but it doesn't seem to do that now,
Do you know if that is a problem and is there a reset I can do?
Cheers dave.
I have the 2023 2.0 TSI Sportline, so I imagine the headlights operate the same. I have the light switch always set to Auto, when I start the car when headlights are needed they come, the beans go up and then come down I assume this is checking the auto levelling mechanism is working correctly. I then move the stalk to Msjn beam position and the dashboard main beam lamp either illuminates blue for main beam or white if dipped beam is in use. I think there is a setting in the Infotainment screen for light settings to activate/deactivate auto main beam/dipped beam. At light I tend to drive on auto main beam all the time, leaving the Karoq to adjust the headlamp beam as required to suit traffic conditions- so far if has worked flawlessly.
Has you Karoq had an MOT recently as that will have checked the headlamp beams are aligned correctly- maybe they have switch off the auto dip to check the beam patterns?
The feature you refer to is known as Headlamp Assist.  To use the feature, the light switch (turn knob) must first be in the “Auto” position.  Then, each time you switch on the ignition, you need to push the headlamp stalk forwards until you feel resistance (about half the full travel), then let it return to rest position.  You will notice the lights indicator at the bottom of the dashboard display shows a white dipped headlamp symbol with “A” in the centre of the symbol.  Unfortunately, the car doesn’t remember this, and you have to repeat this second step involving the headlamp stalk each time the ignition is switched on.
On 19.08.2026 г. at 16:22, RCC49 said:
Функцията, за която говорите, е известна като Асистент за фарове. За да използвате функцията, превключвателят на светлините (въртящото се копче) първо трябва да е в положение „Автоматично“. След това, всеки път, когато включвате запалването, трябва да натискате лоста за фаровете напред, докато усетите съпротивление (около половината от пълния ход), след което да го оставите да се върне в първоначалното си положение. Ще забележите, че индикаторът за светлините в долната част на дисплея на таблото показва бял символ за къси фарове с „A“ в центъра на символа. За съжаление, колата не запомня това и трябва да повтаряте тази втора стъпка, включваща лоста за фарове, всеки път, когато запалването се включи.
https://obdeleven.com/customizations/skoda/karoq/2017-2021/high-beam-assist-memory
On 8/20/2026 at 7:41 PM, RCC49 said:
which it is not yet possible to unloc
Wrong Information
But you need the correct people and Money
Edited by Cairus
Probably true. Not currently possible with either OBD11 or Carista, so until it is, I'll have to wait.
OBD11 and Carista will not receive an SFD 2 license from VW.
And you know this how?
