Diff shaft
I have a klunk when changing gear (mainly low speed) and slightly when lifting off the gas.
Diff shafts seal area’s are leaking slightly on both sides.
In my limited knowledge and based on the below video I’m thinking stub axels and or diff bearings but I would like advice before buying the parts.
The video is both drive shafts grabbed at the box and twisted back and forth.
If the shaft seals are leaking it may be low on oil hence the clunk. I would get gearbox oil level checked and also the condition of it first. Could also be worn cv joints.
Alasdair
Thanks. Oil has been changed recently and is currently just seeping out of the fill hole. Both drive shafts are new from wheel to flange.
Plus 1 for low oil. That sounds like a "dry clunk" to my ears. Could also be dry CV joints.
Edited by SwallownAmazon
Ok so I decided to bleed the clutch as a slight possibility and because I was doing the brakes anyway. It seems that my clunking has gone. Fluid looked pretty s***ty when I first began to flush.
Edited by Morph
Or maybe not 🤔
Reckon if its still there its either worn splines or worn cv joint. Get someone to hold shaft and try turning wheel by hand if its still there it would I think rule out Gbox and inner cv.
Alasdair
