Superb 2 rear suspension sitting too low with new parts
Really stuck for answers with this one. I've owned the car for 11 years so I know its history.
I'm having some issues with my 2.0 TDI 170PS DSG FWD Superb elegance estate rear suspension sitting too low with after market parts and wondered if anyone knows the correct dimensions or what the issue could be?
2 years ago the N/S rear was catching on some speed bumps with only myself in and 2 young kids. I had the car in the garage for repairs and while fixing them, a broken coil spring was noticed. This was replaced, but the the problem never fully went away. A month later work was completed on the O/S rear and again another coil spring was replaced and at the same time 2 rear arms and 4 wheel tracking. These were pattern parts from one of the local suppliers.
The cars been catching ever since and having unloaded everything from the car recently, I could tell that the gap from rear tyre to the arch was far too low.
I took the car to a different garage who put it up on the lift. We could see scuff marks to the underside of the newish rear arms, the fuel tank and the plastic covers that run down each side of the car. We noticed a failed shocker on the N/S and decided to book it in for replacement and while the springs are out, measure them and compare the dimensions against the ones stocked at the various local suppliers.
The dimension is 368mm and the diameter of the springs on the car are the same as a new part.
Skoda themselves won't provide a spring length and say that they only use a 3 colour coding system.
We've ran various history and part checks with local after market stockists and all springs listed seem to be the same.
This then turns my attention to the rear arms, as only the springs and arms have been replaced and the ones removed will have been the genuine ones from new.
I can't buy a genuine Skoda rear arm, because they don't keep them for Superbs, and so if they order one I can't return it and they are £450 each.
I'd normally say that springs determine ride height, but it feels like the after market arms could be the issue, but would they really throw out the rear ride height by an estimated 40 to 50mm?
The fact that the arms have score marks to the underside indicates they are too low to the ground because spring length sets the vehicles ride height over the wheels and chassis. The arms can only sit lower if the geometry is different. The ones now installed have a slight camber to them and the mechanic thinks some can be straighter, so I've asked them to order a replacement pattern part to compare to whats on.
The garage needs the car off the lift so it's going to have to be assembled on Monday regardless and I might still have the same issue.
To summarise:
I have 2 rear arms and 2 rear coil springs installed from 2 years ago and the cars now sitting too low.
Currently replacing both rear shockers and damaged bump stops.
If anyone has a genuine rear spring length and or colour code it would be helpful.
@Carlston might be able top assist with specs.
Try Kilen springs as i had good experience with them as you need ones specific to an estate as it sounds like you have either sport springs or saloon springs causing it to be too low.
For the Superb MK2 2.0TDI 170HP FWD with standard ride height, Kilen list 1K0511115DF rear springs.
Perhaps try the equivalent increased ride height rear springs, ie. 1K0511115CR.
1K0511115CR is about 20mm longer than 1K0511115DF...as you might expect from an increased ride height spring.
To find out what rear springs the car left the factory with, you can use the website "skoda parts com" and put the car in the online garage using its VIN number. Then when the rear springs are searched for, only the correct ones are shown.
Sachs 994336 is sold to replace 1K0511115CR (other choices are available)
https://www.ebay.co.uk/itm/396315502720
Edited by Carlston
@ddan1275 The fact that only the spring on one side was replaced already tells the story: The "garage" doesn't understand his job. Suspension parts like springs (and shock absorbers etc) should always be replaced on both sides!
The fact that the car is now lower than it should be is another indicator for the poor competence of your "garage". Most likely the new springs are not stiff enough for your Superb.
This also leads you to the solution: Go to a proper garage and have them fix your car with quality parts with the correct specifications. You don't have to go OEM, after-market parts from A-grade suppliers (Sachs, ZF etc) are also OK.
About you wanting to measure free spring length: That length says absolutely nothing about the spring stiffness, so there is no use in measuring it. In this case your Skoda dealer is right: Just use a set of springs from a well-known brand with the correct color code, and your ride height will be restored.
See the attached Word document (sorry, it's in Dutch, but the picture should be clear).
The dimension "a" should be
  • 394 ± 10 mm for standard suspension
  • 379 ± 10 mm for sport suspension
  • 414 ± 10 mm for rough road suspension
Voorgeschreven waarden achteras.doc
Edited by andrehj
The OEM part number for the lower wishbone on the Superb MK2, Octavia MK2, and Yeti is 1K0505311AB. This applies to all models, so includes both FWD and 4x4.
What make and model of lower wishbone did the garage fit?
What make and model of rear spring did the garage fit?
"skoda parts com" list both Lemforder and SKF as two alternatives to the genuine Skoda part for the lower wishbone with OEM part number 1K0505311AB
https://www.skoda-parts.com/spare-part/1k0505311ab-lower-rear-axle-arm-skf-52574.html
Edited by Carlston
@andrehj Hi, I've took the car to a different garage this time to try and get things sorted. They only change things in pairs.
The garage thats fit the wrong springs and or rear arms was in October and November 2024.
Local garages now won't let customers supply their own parts but then some garages are ordering the wrong parts. The springs were from TMS motorspares but I was told they have to be tested to the same compression strength as OEM for like for like physical dimensions. The current garage has ordered two new coil springs from Europarts but they are the exact same length around 370mm
At this moment no one can tell me what colour code was originally on the car.
TMS only list 2 springs for this model and have only one of the 2 in stock. The pair they have in stock are different to the ones thats currently on my car that they've previousy supplied and are too short. The replacements are the same length.
@Carlston I've signed up to the skoda parts link you've sent but need to figure it out better as it only allows one free garage search.
Both rear arms were changed in November 2024. The coil springs were changed in October and then November 2024. The cars far too low so the has to be an issue with the springs, but how would that explain the underside of the chassis and rear arms catching on speed bumps? Does this mean springs and arms are wrong?
I'll show this thread to the current garage in the morning.
If the car is too low, the springs are not stiff or long enough. That is a very clear explanation for the car hitting the end stops on speed bumps.
You have a very common engine (2.0 TDI with DSG), so finding out the correct color code for your springs should be easy.
Also, I do not understand your problem with skoda-parts.com. Simply make an account and add your car. If you have two Skoda's, make two accounts (with two different e-mail addresses).
And regarding spring length: I already explained to you before that just measuring the free spring length is useless. You also have to compare the stiffness, which is determined by the wire diameter and the number of turns. But it all starts with the original specifications.
Edited by andrehj
If you want quality suspension parts use avs spares, put it in google. Excellent people. Unfortunately they very rarely show the springs as they can be complicated. However I did work it out and to do so would need a picture of the white vehicle label in the boot.
To be fair though they are bound to be standard estate ones for the vag range of cars.
The original springs should have had Three coloured dots on them. That makes it much easier to just buy the same. See photo as an example. In this case pink brown brown. So for my Audi TT standard front suspension springs.
If you post the label up though I will see if I can tell you.
Without knowing the boot sticker I’d go for these Monroe ones. They are longer than the saloon ones.
Your sticker should look like this. G51 is the suspension set up on mine if you read the numbers.
