Towing experiences with Octavia
Hi all,
My first post here. I recently bought an Octavia wagon/estate on near impulse after my previous car was in an accident. It is 110kw / 250Nm with 8-speed torque converter auto (non-DSG) and the compliance plate says that it can tow 1500kg, GVM is 1883kg and GCM 3383kg & (I think) 80kg max towball download.
I have a boat/trailer that I would like to tow. The boat was apparently built to be 750kg so that, at the time, the trailer could get away with no brakes. I haven't ever put it on a weighbridge but I am going to say that it is 1000kg - ie. boat likely built heavier than quoted, trailer brakes added, plus outboard, & gear. Or even 1100kg to be even more conservative. I dont expect to go destinations further than say a 1 hr drive but there will be a few hills... My contingency was to rent a small truck if the Octavia doesnt work out as a tow vehicle.
The numbers stack up and it should be relatively comfortable.
Does anyone have any experience in towing something similar with their Octavia ? I am interested in the overall feel & dynamics rather than figures and theory. Is this weight really too much for it ? Especially after adding in a couple of passengers and gear to the mix ? How effective does the motor & transmission shed heat ?
Sorry 2nd question - for those that do have a tow bar, what type/style did you get ? Was there any height adjustability ? I had to get an adjustable hitch monstrosity on my previous car so that the trailer would sit flat while towing. Butt-ugly and heavy but it was downright dangerous without it.
Welcome. What engine is it, a 1.4 TSI with the 8 speed auto. Seems sensible to get the car and loaded trailer on a weigh bridge. Or at least the trailer and boat on scales.
Edited by Evolution13
yes 1.4 TSI with 8 speed.
Not so easy to weigh as I dont have a car with a tow bar atm...chicken and egg LOL.
How about a friend or hire that vehicle to get the trailer and boat and all the gear weighed before getting a Tow Bar fitted? Has the Estate got 'Towing Prep' from the factory? and what tow bars are available to you in Australia for the Octavia Estate? ??? What height does the tow ball need to be at to have the trailer level?
At a guess you have a 5 to 6 metre boat on a single-axle trailer? - your Octavia wagon will have no issues towing it apart from keeping a eye on transmission temperatures if you are doing long mountain climbs.
Front-wheel drive can sometimes be an issue on steep launch ramps and it's a good idea to not get the rear of the vehicle anywhere near salt water! - I used to use a towbar extension pole to launch and recover my cruiser.
Edited by Warrior193
correction
I'd suggest getting a fixed type tow-ball, as the removeable type will almost certainly will not be able to allow any height adjustment.
I've seen simple 'drop plates' that just bolt between tow-ball and bar that allow for height adjustment.
thanks all for the comments... No idea if it has any factory 'towing prep' apart from stating GVM and towing values. Seems that I can get the euro style towbars that remove/rotate/hide as well as the hayman reese style with the square hitch - which is pretty much the local default, like https://haymanreese.com.au/products/towbar-to-suit-skoda-octavia-11-2013-on-03386rw
Yes its a single axle, 5.5m trailer yacht.
Is there a transmission temp sensor that can be monitored while driving ? or is it just a warning light that comes on when its too hot ?
@Warriror193 - how heavy was your cruiser that you towed ? What did you tow it with ? Was it comfortable or stressful on the car ?
mine is a 2025 2.0TDI DSG estate and I pull a Mayland Mariner with alot of water trapped in the floor!
You have a"slushbox" which is great for edging forwards (compared with my DSG which has to engage a clutch each time it edges forwards in traffic), but heat buildup on long inclines would be your issue. I am sure the basic "OBDeleven 3" would give you your gearbox temperature, but you'd need to test it beforehand on the same hills to know whats normal, and find out the temp thresholds for your model of gearbox. The max temp is to do with the max temp the transmission oil can handle.
I think on some slushboxes the final drive (top gear) is a locked up gear and this is the one you want engaged as much as possible on the motorway to reduce hydraulic heat buildup (ie. gives it the chance to cool down after an incline).
Bear in mind that the "towing prep" at the factory is the installation of the "J345 Trailer Control Module" (in the case of my car). This changes software mappings in the engine/gearbox and the car can reverse without it thinking it is about to hit a trailer...
Good news according to AI which looks on the ball for once.
11 hours ago, Davema said:
thanks all for the comments... No idea if it has any factory 'towing prep' apart from stating GVM and towing values. Seems that I can get the euro style towbars that M
My most recent tow for long distances in the UK was a Shetland 5.4 metre outboard cruiser on a single-axle tilter - never put on a weighbridge but wet weight was almost certainly a 'bit' over the unbraked limit!
Boat was used for cross-channel cruises and long-coastal around Southern England, so usually carried fuel for around 70-100 miles.
Tow vehicles with that boat were 2.0L Volvo 360, then a 2.2L Vauxhall - both N.A and with lower HP/Torque than the Octavia, hardly felt the weight with either.
I suspect AI is no more sure what the Auto Box service regime is from Skoda / VW than the Main Dealers Service desk staff are.
Thanks guys,
Some great feedback there. That gives me much more comfort & confidence.
Re. your question about checking transmission temperature, there may be a setting in the Maxidot MFD for that - if not a setting specifically for transmission, there definitely is one for engine oil temp.
8 hours ago, Davema said:
Thanks guys,
Does your trailer yacht uses water ballast?
Consider using my idea of a rigid bar extension for launching and recovery - so much easier than using a rope, which of course is only useful for recovery.
@Warrior193 I ever had any showing of Automatic Gearboxes temperatures on the dash with any of the dozens if not hundreds of 2 pedal vehicles i have had since the 1970,s.. Plenty had a Overheating warning including VW Groups with a DSG or Tiptronic. Never had a VW Group vehicles with an TC Automatic.
