SD cards and the Amundsen infotainment system.
I guess this has been asked and answered dozens of times but I've trawled and found nothing recent.
A few problems.
I'm really struggling to update the Nav system.
  1. I only have access to a Mac, on OS 26 Tahoe.
  2. Can I use a new card that IS NOT a Skoda original, or must I stick with what I have?
  3. The Mac seems to insist on writing extra files to the SD card and messing up the install.
  4. Can I simply 'unhide' and delete these files, or is something else needed?
Naturally this has all caught me out with 2 days to go before a big trip - when a Satnag would be very useful ...........
The Skoda Update Portal seems to say any SDS card will do - but it won't ......... unless I've missed something fundamental.
HELP!!
If you have Amundsen MIB2, you will need to use an official SD card. It may pay to get a 32gb replacement card if your original one is only 16gb.
Edited by Warrior193
correction
Patch Unit and you can use every SD Card
Please explain. I'm O-L-D. 😁😁
What is 'Patch Unit'?
If using anything other than a Skoda original/coded SD card, is it possible to use a card larger than 32Gb? (I have several ......)
Yes
Amundsen maps need to be on an SD card that had the correct ID so it is (or looks like) a genuine Skoda card (or it appears you can hack the Amundsen to accept maps any card) - I use a 32GB genuine card I got off eBay.
Amundsen music can be on any SD card - I use a 256GB SD card.
The CID in ASCII simple "MIBSTD"
OK, forgive the ignorance.
What do I need to do/add to an ordinary SD card to make it work as the Satnav data storage?
(that's if it can be done .... )
Picture of actual Software train.
Press Long Menü, Service Menü Open, Then Software Update, then picture
Edited by Cairus
Thanks.
I can get the first three stages, no problem.
When I get to Software Update, it offers the current, then a second choice. I am nervous of the 'poke and hope' approach, so where do I go next and what card should be in the SD (1?) slot?
Can I also ask what you mean by ''then picture"?
You have to Share the Picture Here which Software train is installed
Got it. Hope these help:
Eerrrrrr! Excuse all the dust. Need hoover
Update Firmware 253 then Patch
How?
Cairus: I need more information, a drip-feed, a link to something that explains in terms clear enough for an idiot.
I do not even seem to now have an SD card that the system will read, let alone load with a firmware update. Even if I did, where is that firmware?
Quick update: I'd had the sense to back up the old map files on the Skoda SD card. I formatted the SD card to FAT32 and put/copied them back onto the card. Then I deleted the two files the Mac seems to have added.
I put it back in the unit and I have maps back, even if well out of date and limited to UK and parts of Europe. They will do for now - but I still need to get this thing updated and new maps installed.
If there is a Firmware update and a 'patch' that will get round some of these issues, I would be very grateful for the information on how to do that.
If you just want maps the Official Skoda website has them available for download , as long as your Official Skoda SD card has enough space for the new maps you will be fine, some older official Cards are to small for the new maps to fit on, hence why people suggest a new larger "Official" card (the standard MIB2 Units are locked down to only use official SD cards).
The mib-helper website is a good place to start for information about updating or patching you system, or there are some very good YouTube Videos on the subject too.
Thanks for that. The SKODA card I have reports at 16Gb. I tried the UK and western Europe map, (ECE 1) downloaded it, formatted the card FAT32, then unzipped the map onto the card with 'Unarchiver' which seems to have a decent reputation with Mac OS. The zipped file is 8Gb and the site says a 16Gb minimum is needed. Should be fine.
The result of that effort is what appears in photo 4. A fail.
Simply selecting NAV, then following the prompt to insert the card tells me it's accepted the card OK as a source of Nav data - but then it says it can't use it or words to that effect.
Doesn't seem to make sense.
I'm just wondering if the Mac OS is putting something else on there that I can't see when the file is being unzipped which then screws up the card.
Thank you. That's a much better guide than I've seen anywhere else. I'm going to print it and stick it in the glovebox.
I have ordered a 32Gb 'clone' card to see if it helps and I'm going to try and find a Linux, or Windoze machine to use for the job. In the meantime, I'll leave the old card alone (it's working for now, don't tempt fate) accept the older info and make my journeys next week. I'll have a Co-Pilot with me who has a 6th sense for direction - I kid you not, he's uncanny.😁
When the clone arrives, I'll play with that and see where I get to.
MacOS does add extra files - you need to use a MacOS app such as BlueHarvest or CleanEject to remove them.
