Windows, Mirrors and Doors Issues
Hi all,
Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on.
Drivers (right hand) door only opens using key manually in lock.
All other central locking works ok.
Rear o/s door does not open from in or out (deadlocked)
Both front windows and mirrors temperamental.
Looks like the cables through the drivers door have a had small solder/fix at some point.
Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom?
I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
Broken wires in the body to door trunking are common on higher mileage cars.temperature Also a failed lock on the drivers door.
The drivers door lock replacement is expensive in labour as the inside metal door panel has to be drilled out to remove the window mechanism in order to replace the lock. I know because my window winder failed and I had the intermittent lock replaced at the same time (temperature sensitive failing microswitch in the lock).
I suggest you talk to a good auto electrician for advice. Mine says he regularly replaces locks, particularly on Audi A3s. He frequently fixes broken wires to the driver's door.
Same with mirror controls but another cause for intermittent mirrors and window winders is the switch assemblies. Relatively cheap to replace as a diy job.
