Non Return Valve?
My 3 cylinder, CGPA, 12v engine is struggling to start after it's not been used overnight. It turns over OK but coughs and splutters. On second attempt it starts straight away, as it has always done on the first turn of the key up to recently.
My VAG code reader does not show any fault codes.
I'm wondering if the cause is lack of petrol fuel pressure caused by a failed non return valve.
Is there a a NRV in the fuel system?
Or could there be an auto choke process that isn't working as it should?
TIA
I don't think so.
Does the fuel pump prime when you first open driver's door?
