Octavia II 2.0 TDI CFHC – repeated throttle actuator failures + new P242C EGT sensor fault
Hi everyone,
I’m looking for some advice regarding a recurring problem with my Skoda Octavia.
Car details:
  • Skoda Octavia II (1Z)
  • Model/type: 1Z523C
  • 2.0 TDI Common Rail
  • Engine code: CFHC
  • 103 kW / 140 hp
  • Model year: 2013
I have been having recurring problems with the throttle valve/throttle actuator for several years.
The throttle valve has already been replaced three times, approximately at two-year intervals.
What concerns me now is that after the third replacement, the fault has returned after only about five months.
The current diagnostic scan shows the following faults:
P2100 – Throttle Actuator Control Motor Circuit/Open
Status: Active/Static
P2111 – Throttle Actuator Control System – Stuck Open
Status: Passive/Intermittent
P242C – Exhaust Gas Temperature Sensor Circuit Low, Bank 1 Sensor 3
The P242C fault is new.
During the previous throttle valve failures, I only had faults related to the throttle system; there was no exhaust gas temperature sensor fault.
After having replaced the throttle valve three times, and with the latest one apparently developing a fault after only five months, I am starting to wonder whether the throttle valve itself is really the root cause.
Could there be an underlying problem causing repeated throttle actuator failures, for example a wiring/connector or electrical supply problem, an EGR/intake-related issue, excessive contamination, or something else specific to the CFHC engine?
I’m also interested to know whether anyone has seen P2100/P2111 together with P242C on this engine. Could the EGT sensor/circuit fault somehow be related to the recurring throttle problem, or are these most likely two independent issues?
Before replacing the throttle valve for a fourth time, I would really like to understand why this keeps happening.
Has anyone experienced something similar on a CFHC 2.0 TDI, or can suggest what should be checked next?
Thanks in advance for any technical advice or experience.
Best regards
Luca
Might be a wiring/connector issue to the throttle body. It may be that when new the pins make decent contact but if plug on wiring loom end is loose/coroded/worn pins over time may be breaking contact and causing problem. The p242c is either the EGT sensor iss failing or perhaps broken wires.
Alasdair
