Re-gen frequency
2016, 150 bhp diesel.
Re-gening on avarage, every two days now.
Had the soot content checked....20%. Never had any warning lights on in 3.5 years, and when I know its doing the business, I tend to drive in the appropriate gear to get the revs up to 2500-3000 rpm for 20 mins to clear it, which it does, and then runs fine for a couple of days before a repeat performance.
Doing my head in, with the usual strange looks as the fans kick in for 10 mins when I finally stop if it hasn't already cleared.
Is this normal?
How often is the car doing only short trips / cold starts, & how far, or doing longer journeys & how far are those trips? ,
Might be a failing dpf pressure sensor or the ash content is very high. Might be worth getting a quick vcds scan to see if there any stored and check ash level at same time. My octavia does the same but only getting short runs these days. When it happens I try and give it a decent long run.
Alasdair
Alasdair
Ash content was 20%, which I was told was quite good/normal for a 71,000 miler.
I do regular 10 mile runs around town..ish, and a 15 mile there and same on return blast down my local motorway once or twice a week.
As I said, I hold the appropriate gear to keep the revs up to 2500-3000 as much as possible when I sense it's regenerating....usually when the mpg won't go above 43.5 whereas it's usually in the low 50's
Never had an issue, and do lob a bottle of DPF cleaner in the tank a couple of times a year too to try and keep on top of it.
I'm probably worrying about nothing.
Absolutely love this car btw.
Edited by Adenuf
Was it soot or ash content or both that was 20% Soot gets burned off during regen but ash builds up over time. Next time it happens I would take it out for a decent long run and see how long it takes for it to regen again. With mine its random. Recently after decent run it took over a two weeks to start regen again but if I do short trips it starts regen about every few days until another long run. Check the dpf sensor isnt melted. Read a few reports that on ea288 engines the sensor is prone to heat and can melt/be damaged.
Alasdair
Is this normal?
Hi Adenuf
Same problem here, already checked the filter and its ok, values are regular, but regen every 31 miles...
Changes the lambda sensor because of fault 1 month ago and now going for the DPF sensor and tubes, will give feedback here
  • 4 weeks later...
Solved!!, changed the Sensor G450 my self (51£) , very easy to do. there are two of them on the top back of the engine. one of mine was already changed, so i changed the back one, and the car now is regenerating almost normaly, about every 200 miles mixed circuit but 40% city stop and go trafic.
