Two goes at pulling away !
For some time now, almost everytime I pull away (backwards or forwards) it leaps, pauses and then pulls away as expected. I've asked the question of various persons in the know but failed to get a fix. Two weeks ago, I had the front brake pads replaced. They were getting "grabby" and were well worn down. Almost immediately I noticed that pullimg away was much smoother. The second go at pulling away trick has now gone. I can only think that the front pads were intermittently binding up on the disc and letting go at the second push.
Hopefully, this will help someone else with the same or similar issue.
My superb does this a bit. It’s got 130,000 miles on the clock and previous owner missed a gearbox service so I generally forgive her a little jerkiness.
If you have vcds or carscanner or similar you can adjust the autohold sensitivity which may help.
