Skoda Rapid 2018 – BCM Upgrade (6C0 937 087E to 6C0 937 089E) – Remote Window Closing
Hello everyone,
I have a 2018 Skoda Rapid and I recently upgraded the BCM (Body Control Module).
The original BCM was:
Old BCM: 6C0 937 087E
I replaced it with:
New BCM: 6C0 937 089E
Both BCMs are Lear / VW AG units.
My question is regarding the comfort window closing function.
After upgrading from 6C0 937 087E to 6C0 937 089E, is it possible to enable a function that allows me to close all the windows by pressing and holding the LOCK button on the original remote key?
I would like to know:
  • Does the 6C0 937 089E BCM support remote window closing?
  • Can this function be enabled by coding/adaptation only using VCDS, ODIS or OBDeleven?
  • Do I need to install any additional hardware or modules?
  • Is there a specific coding or adaptation channel that needs to be changed?
The car already has electric windows and I am using the original Skoda remote key.
Basically, I want to press and hold the LOCK button on the remote, and have all the windows close automatically, without adding any additional hardware.
If anyone has experience with this BCM upgrade or knows the exact coding/adaptation required, I would really appreciate your help.
Thank you!
