Rear washer and heated rear window
Skoda Superb elegant 2018
Hi my rear washer stopped working a while ago and now the demister doesn't work. I have checked all the fuses under the bonnet and all OK i have shoved a needle down the washer head and no blockage. Is there any other fuses anywhere? Or any advice on fixing the problem
For the rear demister, check the loop of wiring between body and hatch for broken connections - for the washers, is there any sign of water ingress in the trunk?
