Can anyone help identify these hoses/parts
Hi all, had an intermittent engine warning light with an error code that reference the vacuum pump.
Local garage quoted me near a grand to replace the two hoses shown in the pictures, but that seems insane to me. Can anyone help me identify the parts/hoses so I can order them and replace myself.
To get a quick answer, please tell us which engine and MY your have. It may help... 😉
Thanks for the heads up Bap33!
It’s a Kodiaq 1.5 petrol from 2020 ☺️
oil evapour, gasoline evapour
Hi imart143!
Thanks so much for your help.
Managed to find the oil vapour pipe online (Google told me it was also called a crankcase breather hose), but the gas one is proving a bit more difficult.
Could anyone provide a link to the right replacement or suggest what else it might be called?
@Cgwchris Was that local garage quoting near £1,000 to replace or a Skoda main Dealership? Was that after a Tech or Master tech inspecting the pipes?
Edited by Evolution13
in original, VAG have complete system with valve and its expensive, i had minor leaks and diassemble hoses from engine and this rubber is not bar, but plastic one have few leaks, i used selfvulcanization tape and I wrapped the entire ribbed pipe with it, 2 years ago, and everything is still fine. It's oil-based, this rubber fuel-based one never cracks.
https://www.3m.co.uk/3M/en_GB/p/d/b00011942/
