Chime after locking and unlocking car
Hi Guys,
Everytime I lock or unlock my car this chime sounds and not sure what it is. Nothing is left on lights etc. I have problems with battery drainage after 3/4 days of no use so thinking it could be something to do with that maybe.
Cant hear chime sound on clip but it may be the siren battery thats failing and car is continuosuly trying to charge it hence drain over 3-4 days. You could pull the fuse for the siren back up battery. From memory think its fuse 35 in side of dash and see if it makes a difference. Might be worth a scan with vcds to see if it pulls up any random faults.
Alasdair
Meant to add it may be a failing ignition switch. Did read that there is a plastic bit/switch that lets the car know if theres a key in ignition. If it sticks the car assumes theres still a key in so doesnt shut down properly and beeps to warn you about locking key in car. Read it on a VW forum so may not be aplicable to mk2 octavia Maybe someone on here could help. They said try a squirt of wd40 into ignition to see if it frees up plastic bit,
Alasdair
Hi. Thanks for the reply I’ve tried the fuse 35 and it’s still happening. Does this video help any better? This is the noise I was on about.
Cheers
Tom
Does the cluster go blank when key is removed and car is locked. When I was working on my sons fabia I left key in ignition and battery went flat over two days. As said it may be a faulty ignition switch and car thinks key is still in it so not shutting down.
Alasdair
