Axle stand location
I know others had this problem, but can't find a definitive solution. If I jack up the rear of the car using the reinforced sill-weld, I then have nowhere to put an axle stand. I'm reluctant to pick a suspension member, not being confident it won't get damaged. I noticed just in from the jack points there is an oval plastic cover that comes off and reveals two circulare rubber bungs a few cm apart. I have seen elsewhere someone jacking a Tiguan on this zone using a block of wood as a spreader, saving the sill weld for axle stands. Is this good practice?
Thanks!
Hi, the below shows what you described and with a nice chunk of wood to ensure you won’t damage anything I would say this seems fine.
Just to add - the jacking point on the sill is actually only for emergency use. The car isn't designed to be lifted here, if at all possible. Absolutely get a decent jack pad.
