OBDeleven/VCDS default values for front left fog light
I was playing around with OBD11 a bit too much, now I get a persistent dash warning for the front left foglight and the code B121F15 in obdeleven.
Under Module 09 adaptations, for channel Leuchte12NL LB45 (front left fog light) I set Lichtfunktion B 12 = Abblendlicht links.
This caused the front left fog light to always be on with the low beam, the moment I disabled it the error started showing up.
I suspect that changing that adaptation also changed Lampendefektbitposition and Fehlerort mittleres Byte DTC-DFCC.
Could anyone with a facelift model with the LED fog lights and Matrix headlights be kind enough to share their values )
Alternatively, I'm also not opposed to just disabling that check if possible.
Recently Browsing 1
