Mark 2 l&k headlights
This is driving me nuts. In my headlight cluster, there are 2 bulbs. A short one with a wire attached, and the bulb cannot be removed. It is held in by a spring clip.
What should I be looking for if I need to replace it?
The wire has a spade end which can be disconnected to completely remove it once the spring clip is undone
It lights up on full beam after the main bulb stops moving
Silly question, I know, but as I said, driving me nuts on the net.
If your profile is correct, and you have a 2012 Superb then that will be the h3 main beam bulb.
Put your reg into https://www.autobulbsdirect.co.uk/ and it will give you the correct bulbs for your car.
Why do you think that the bulb cannot be removed ?
