Can I enable Indirect (ABS wheel sensor based) TPMS on 2012 Yeti SE?
Does the signal chime occur after the pairing process?
I have never Edit Controller 4c
On Cluster Software 608 tpms Reset dont work
Edited by Cairus
No signal chime during coding, but I do see the dash symbol and sometimes it's flashes. It seems this process involves at least two things - The ABS controller 03, and instruments 17. VCDS gives me the long coding helper and check boxes to code bits to enable TPMS. Perhaps Ross Tech got something wrong and I should look further into how the bytes are coded. I don't think Skoda want MY12 Yeti to have ABS TPMS!
Give me some time, I'll screen grab all vcds long coding screens with TPMS tick boxes and hope somebody can make sense of them or suggest something has to be done that's missing.
My white screen display did once add TPMS and a reset option to the settings menu, but this was after I code enabled every entry in vcds refering to TPMS. Then I got a bunch of Gateway errors. My older V.W has nothing in the Gateway list enabled for ABS TPMS. There were 2 options in my Yeti Gateway controller list - 4C and another at 6? Although each can be enabled, they error on scan with no communication because it seems they are additional hardware controllers (I suspect for internal tyre sensors?)
I thought taking it for a short drive it would learn sufficient to flag the large tyre pressure change but it didn't change anything. I've found a relatively cheap TPMS switch kit with wiring on Ali, but I'm not optimistic. It appears to have a local indicator backlight led wiring. I would be better reassured if after pressing the switch there was an acknowledgement of some kind 'ding' or dash symbol flash.
I've already read the post link instructions from langers2k and tried it several times. You will see mention of module 4C (Tire Pressure II) which the OP added to the Gateway list. I also get the new Tyre pressure section in MFD settings. But MY12 knows nothing about 4C and won't communicate when enabled and what is 'Tyre Pressure II', something different to Tyre Pressure or TP 1? Do you guys have module 4C showing in your Gateway list without error codes?
Edited by voxmagna
