Crank but no start 2.0TDi
So I tried to start my 2.0TDI crmb engine this morning and I had crank with some spluttering but no start. I've had this a few weeks ago but after a few cranks got it going, but today no luck.
It's cranking between 500-1000rpm, glow plug light is off and after failing to crank i getting brake manoeuvring unavailable. I have a new battery replaced on Thursday and coded correctly, tested it and it was showing at 12.4v.
Any ideas on what it might be? Anything to test?
I would have said 500-1000rpm was pretty fast for just cranking. Wonder if the crank or cam position sensor has failed. Reckon a scan with vcds or similar might be in order. The brake manoeuvring unavailable may be down to the long cranking and voltage drop. As said see if there are any fault codes stored.
Alasdair
Glow plugs? As @Alasdair1 says, get it scanned.
So scanned it no codes, thinking it may be a sticky throttle body. I had the issue a few weeks ago and pressing the accelerator got the car running.
Tried cranking it again and it the engine is spinning up to 1000rpm before dying so kind of implies it is starting to fire but is failing, fuel pump is activating when cranked, looks like it will have to go to someone to get this resolved.
Check timing belt to see if the camshaft pulley is actually turning then also check EGR valve and intake valve arent stuck closed. I would try without airfilter as well just in case its blocked. It could be a fuel issue so might be worth checking the actual fuel rail pressure.
Alasdair
Issue has finally been resolved, Cylinder 3 injector had failed and was leaking fuel back to the pump. Now I probably need to replace the other 3 at a cost of nearly €300 an injector for the part alone.
Just as I thought this issue was over 24 hours later engine has developed a loud tick, most noticeably over cylinder 3/4, it's being taken back to the mechanic first thing in the morning not too happy with this, I thought it sounded a bit off when I picked it up, my father in law heard it yesterday and was like there's an injector sealing washer gone.
So the latest update on this, turns out cylinder 1 is over fueling which is causing the ticking, all other injectors have been inspected and appear to be in good shape, looks like I will eventually have to do the other 2 injectors
Recently Browsing 1
